WinError -2147024893
Cannot install because Windows can't find the path: WinError -2147024893
I've tried to turn off all security and ran the .exe as admin. Streamer log attached.
Any takes on what might be the problem?
Rushikesh.kadam
@Anonymous Can you try the below similar troubleshooting links?
  1.  https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
  2. https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Did not fix it. The file the system can't find is on a external server. The Fusion Cleaner returns a message: "Cleaning process finished with some errors"
I.ve fixed the problem. I'm not sure what worked. Could've been as simple as my desktop was stored in a cloud. Moved it into the C: directory.
