Windows 11 issues
Windows 11 issues
chrisparris01
Windows 11 issues
chrisparris01
I have just built a new PC and installed Windows 11. Downloaded Fusion, but i cannot get it to run. Is anyone else having problems with windows 11
jhackney1972
No, none whatsoever.  You need to clarify, did it install correctly or at all or just will not open up?  If you would gather up the log files and post them, especially the autodesk.webdeploy.streamer.log it will help.  You can get these file by running the Fusion Service Utility.
John Hackney, Retired
chrisparris01
It won't open; I have uninstalled and reinstalled it several times. I dropped the last attempt at the Applog.
Thank you for your help
Chris
jhackney1972
Your log file indicates that the application did not install correctly.  Here is a line from the log file:
You may want to take a look at this Support Forum post and especially Message #4.
Good Luck,
chrisparris01
Hi, Many thanks for your help with this. I tried the steps in message #4, and it did not work. I have been using Fusion 360 on various PCs and laptops since 2016 and have never had this issue. I've missed two days of work trying to sort this out, so unfortunately I'm going back to Solidworks.
Again many thanks for trying to help
ChrisP
