Problem sending Tinkercad to Fusion 360 after adding lettering.
RWoerz
Message 1 of 1
RWoerz
As soon as I add some lettering to a model in Tinkercad and try send it to Fusion 360 it turns transparent. It turns transparent in the window between Tinkercad and Fusion. At that point the SEND button is grayed out. Also in Tinkercad some of the letters and numbers (maybe others) in the right hand selection pane there is nothing in the little square. When you hover over the square it will pop up what's in the square. Even though nothing still shows in the square you can drag the object onto the work surface. Hope that makes sense. Not sure if it's some of the mystery letters causing the transfer issue.
Replies (0)
