Windows 10 Update and Fusion Will Not Open
utekcnc
Message 1 of 20
utekcnc
Windows 10 updated and now Fusion will not open.   Nothing happens when I try to open it.   This happened several weeks ago and I ended up uninstalling and reinstalling.  Surely I don't have to do that again?
Replies (19)
Message 2 of 20
James.Youmatz
Autodesk Support
Autodesk Support
Hi @utekcnc,
Hmm, that is strange. Just to check - are you just using the desktop icon for Fusion? I'm curious if maybe this is what is breaking when Windows updated. Does right-clicking and selecting Run as Admin work? One other thought too - if you open Task Manager, are there multiple Fusion 360 processes running? If you restart your computer that should resolve any stray processes interfering with Fusion opening.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 3 of 20
utekcnc
It does the same when I run as admin.........hour glass thingy for a few seconds and that's it.   I have tried restarting also.   A background process does open when I try to open Fusion.   See attached screenshot.
Message 4 of 20
utekcnc
I'm needing to work on Fusion, does anyone have any ideas for me?
Message 5 of 20
utekcnc
Up to the top again, could someone in support please chime in?
Message 6 of 20
paul.clauss
Hi @utekcnc
Thanks for posting! Another customer had this issue yesterday and was able to resolve it with a clean uninstall and reinstall - unfortunately my first recommendation would be doing so. It is possible that the Windows update made changes in a shared folder that Fusion uses to launch. Using the automatic clean uninstall utility tool should make this an easy process for you and choosing to maintain your local cache should mitigate the risk of losing any work.
Hopefully this helps! Please let me know if you have any questions - I am happy to assist.
Paul Clauss
Product Support Specialist
Message 7 of 20
utekcnc
Ok, I had to do that a couple weeks ago......I'm not sure why.....  Thank you
Message 8 of 20
paul.clauss
Hi @utekcnc
Thanks for the response! Because Fusion 360 does use files and folders in shared directory locations, Windows updates can effect Fusion 360 by altering the file-or-folder paths. This can usually be easily resolved with a fresh install of Fusion, but it can be a bit of a pain! Fortunately, the automatic clean uninstall tool should make this process easy.
Paul Clauss
Message 9 of 20
I'm guessing it's safe to assume I should save all of my files to an external folder? gonna do a clean install now, as i have the same issue after the update. Says the software renderer is being used and that my graphics card may not be fast enough. Highly doubt that as this is a new computer.... LOL
edit: Or is all my stuff saved to the server? still new to fusion (only been using this for about a month)
Message 10 of 20
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
All your data should be backed up to our A360 servers as long as you were working online. You can verify this by checking here. Regarding your graphics driver - that does seem strange. Do you know what graphics card you have? Also, within Fusion 360 if you go to the Help menu and select Graphics Diagnostic - what is it reporting for a GPU device?
James Youmatz
Message 11 of 20
It shows the correct GPU: geforce gtx 1060 with 6114 mb. I did a clean install, restarted my computer and it worked right away. Still a pain in the butt do have to do that to get it to work after the update, but life goes on!
Message 12 of 20
utekcnc
I am going to have to do an clean uninstall again and reinstall.   Is there anything to keep from doing this every couple weeks?
Message 13 of 20
paul.clauss
Hi @utekcnc
Unfortunately, the current solution to issues caused by Windows 10 updates is to perform a clean uninstall and reinstall Fusion. You can make this process easier by using the clean uninstall utility tool, which will give you the option to maintain your local cache. This will minimize the risk of any data loss while wiping Fusion from your computer.
I believe this issue is occurring because the Windows update makes some change in a shared folder that Fusion uses during launch and normal operations. We have also seen some issues in which the desktop icon is not updated during a Windows update. Before uninstalling Fusion, please attach your log files to this forum thread and I will have a look and pass them along to our development team - this will help us learn more about the cause of the error you are experiencing.
We are aware that that doing an uninstall every time Windows updates is not ideal - I apologize for any inconveniences this has caused!
Paul Clauss
Message 14 of 20
utekcnc
Ok, thanks
Message 15 of 20
utekcnc
Ok, I did a clean uninstall and reinstalled and still will not launch or open.   It will not open in admin mode either.   I am getting pretty discouraged.   Any ideas?
Message 16 of 20
paul.clauss
Hi @utekcnc
I am sorry to hear that the clean uninstall/reinstall did not resolve this issue. Would you mind gathering your log files using the procedure in the screencast below and attaching them to this forum thread so we may continue looking into this issue?
Please let me know if you have any questions!
Paul Clauss
Message 17 of 20
innovatenate
Autodesk Support
Autodesk Support
@utekcnc I couldn't help but notice in the task manager screenshot you shared that you are using comodo anti-virus software. I currently have a case open with another use and this is my #1 suspect. (That anti-virus software is interfering with the normal operation of Fusion 360).
Can you try adding exception to the setting in comodo to exclude the installation directory of Fusion 360? Please see the below links for more information:
I hope this will help! Any quesitons, please let us know!
Nathan Chandler
Principal Specialist
Message 18 of 20
utekcnc
Ok, I finally had time to deal with this.  Comodo anti-virus was the problem.  Thank you
Message 19 of 20
innovatenate
Autodesk Support
Autodesk Support
Thank you for confirming! I'm glad that was it!
Nathan Chandler
Message 20 of 20
genofurry477
Hello, I'm from the far future of 2021
Four years later and windows updates still break Fusion 360.
You would think that after almost half a decade they would fix this.
Still, the only solution to fix this problem is to completely uninstall fusion, and then reinstall it.
I personally recommend anyone who is tired of the lack of stability, support, and general common sense to check out Free cad, plenty of support, actual stability, and no company behind it to put profits above usability.
