Will this Macbook run Fusion360 well?
As mother of a son who works with Fusion360, I have a question.
I want to buy the Apple MacBook Pro 13'' (2017) MPXR2N/A Silver with this specifications below.
Is it enough for my son to work with Fusion360 on ths laptop?
Really thank you for helping me 😉
Product
Artikelnummer782849
FabrikantcodeMPXR2N/A
MerkApple
Garantie2 jaar
GarantietypeCarry-in-garantie
Beeldscherm
Schermdiagonaal 13,3 inch
Scherpte Retina
Verversingssnelheid 60 Hz
Touchscreen Nee
Reflectie scherm Glanzend
Paneeltype IPS paneel
Adaptive Sync Nee
Beeldscherm kwaliteit Topklasse
Processor
Processor Intel Core i5
Processor-nummer 7360U
Processor kernen Dual core (2)
Processor codenaam Kaby Lake
Kloksnelheid 2,3 GHz
Turbo snelheid 3,6 GHz
Cachegeheugen 4 MB
Werkgeheugen
Intern werkgeheugen (RAM) 8 GB
Geheugen uitbreidbaar Nee
Maximaal intern geheugen 8 GB
Samenstelling geheugen 1 x 8 GB
Geheugenslot 1 8 GB
Totaal aantal RAM geheugensloten 1
Opslag
Type opslag SSD
Totale opslagcapaciteit 128 GB
Opslagcapaciteit van SSD 128 GB
Aantal SSD's 1
Type harde schijf M.2
Videokaart
Videokaart chipset Intel Iris Plus Graphics 640
Soort videokaart Shared
Besturingssysteem
Besturingssysteem macOS
Taal besturingssysteem Engels, Nederlands
Draadloze verbindingen
Mobiele dataconnectie Geen
Wifi standaarden Wireless AC
Bluetooth Ja
Bluetooth-versie 4.0
Bedrade verbindingen
Usb-aansluiting Ja
Aantal usb-aansluitingen 2
Aantal usb 3.1 Female usb-C poort 2
HDMI-aansluiting
TrippyLighting
That somewhat depends on what you and your son are doing with Fusion 360. If you can share a screenshot of models you'd be working with that would likely help.
You already labeled the on-board Video card in red so I assume that you are aware that there are limitations.
For beginning steps in Fusion 360 that should be fine but for models with a lot of complex geometry this will be a problem.
One way to reduce the burden on the GPU is to turn off all the graphics gimmicks in Fusion 360.
Macs have a relatively high resale value compared to PC's. If you find that it runs out of steam, provided you've treaded it well,  you can sell it and upgrade to another used one.
Thank you for your quick answer!
I really appreciate it.
He only is 13 years old so I think the geometric models would not be that complicated.
The most important for him is to learn and to practice with the program.
So as I understand from you it will fitt for the first time...
Just Another question; if he works at home at an apple version form Fusion360 and at school at a windows version, will it be compatible?
Thank you in advance,
Marina
g-andresen
YES!! > identical UI
günther
