Why some transparent, others not?
William_Dec_45
Message 1 of 13
William_Dec_45
It's been a while since I've used Fusion, a little rusty. I try to figure things out first, then the forum. I can't understand why one of these files shows the design transparent while the other one is not. Any help will be appreciated.
Replies (12)
Message 2 of 13
jhackney1972
When I open up both, they look the same visibly.  I can guess it is you Display Setting, Visual Style.  Check out the screen capture below.
John Hackney, Retired
Message 3 of 13
William_Dec_45
Hmm. Thank you for the response. I tried the various display settings at the bottom of the screen. None of them change the transparency. And I haven't been into my main preference settings in months. I'll keep digging.
Message 4 of 13
William_Dec_45
You were right. It was in the display settings. Some of them I didn't test before because I knew I had never used them. The solution was to uncheck all Object Visibility options. Something I've been doing activates them. Now I know what to do about it. Thanks again.
Message 5 of 13
jhackney1972
Take a screen capture of the issue.  Models sometimes do not transfer between two installations of Fusion 360 the same way.  A picture of what you are seeing will maybe help diagnose the problem.
Message 6 of 13
jhackney1972
Do not forget then to Accept Solution to close your Forum post.
Message 7 of 13
William_Dec_45
I was holding off on sending an "accepted" note after your suggestion for
screen shots. Something's still not right. I'm sure as always that it's me,
but I really need to nail it down. It may take a few days before I get the
screen shots up and issues discussed. Sometimes, the hardest part for me is
adequately explaining my problem.
Message 8 of 13
William_Dec_45
Here's a simple tray that I drew. As you can see in the screenshot, it's
transparent. I've done nothing different (that I'm aware of) from what I
usually do and I usually get an opaque image. I can make a change at the
bottom of the screen and make it opaque, but it will reverse my preference.
Any help much appreciated.
Message 9 of 13
jhackney1972
You forgot to attach your screen capture, I see not pictures.
Message 10 of 13
William_Dec_45
I sent them as replies to email. I guess that's a no go. Will take care of
it.
Message 11 of 13
William_Dec_45
Here they are. Thank you.
Additional info: As it currently stands, I'm having to toggle back and forth from Object Visibility (all checked or none checked) to see things I need to see at certain times.
Message 12 of 13
jhackney1972
I opened your model and it look to me just like your screen capture.  What might be confusing you are two things.  You have a sketch visible, it will always show through your model.  Second, you have two separate bodies in your model.  In the Screencast I combine them into one and you can see the edges disappear.  I attached your model with the sketch off and the two bodies combined into one.  Is this better.
Message 13 of 13
William_Dec_45
Thank you, John! You nailed it. Only a few months ago I wouldn't have been sucked into those rookie oversights. One gets rusty quickly. I don't see anywhere on this form how to accept your solution. I'll dig around until I find it.
