- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Besides "recovery saving" about every 5 minutes, it is apparently pummelling the CPU and memory (RAM). I can manually save, and within seconds, the "recovery save" kicks in and my CPU and memory fans go into high-gear and "Fusion 360 is not responding..." Anyone else seeing this issue? I have not installed anything new.
I am on an Alienware gaming system with 32 gigs of ram, and 8 gigs of dedicated video RAM with the GPU (Geforce GTX 1080)... and I only have one model open. There is no reason it should take 15 to 20 seconds to "recovery save" a single model, which is strange because it also still periodically "auto-saves" too... seems a little redundant, I know there is a difference, I'm just saying it's a lot of saving and slowwwwww, OMG this recovery save is murdering me. All the same models I always work with and only making minor iterative changes. The timing syncs up with the latest version and boy is it painfully slow with the recovery save, so much so it behaves like it has a memory leak. After I am ready to put myself out of the misery of this, I have just enough energy left after saying "what the hell?" about 100 times to restart the system (only Fusion 360 is running) then it will go a faster for about an hour, or so but it slowly ...uh...slows down more and more. And I am not even doing CAM at all. I am afraid of what kind of slow death that will feel like. It's so bad, I had to remind myself that the software isn't watching and waiting until I am extra tired of this then BOOM! there it is again.
Standard stuff, yes, fast internet, no I have not deleted all the projects from my hub's dashboard, everything was going swimmingly until the last update (2.0.5357), plenty of hard drive space, no I have not had too many beers again (yet). And, unfortunately, I cannot share the models unless you are in the military with active security clearance. They are pretty basic assemblies with with less than 25 parts in a single model (each). I guess I am trying to figure out if others are seeing this same thing.
Thanks, guys.
