Why is my custom appearance on my model fluctuating between light and dark?
louisR784F
Observer Observer
louisR784F
Observer
Observer
I modified the default linear brushed aluminum appearance to use a different image, but it is causing a lot of issues in how it appears on my model in the Design interface as well as the Render interface. It is usually extremely dark despite the brightness of the image I used being set to 100. As I rotate and zoom in on the model, the appearance will fluctuate between really dark and light on the different bodies. See the attached photo for details. I tried adding some emitters to my design space, but even when they were really large they didn't have an effect on this fluctuation glitch. Any advice or suggestions would be much appreciate!
TrippyLighting
Can you share your model ?
If so, please export it as a .f3d and attach it to a post.
This could be a Z-Fighting problem, but I am not sure.
louisR784F
Observer
Observer
Sure thing, it is attached. Thanks in advance, Trippy.
louisR784F
Observer
Observer
Any update?
TrippyLighting
I have no idea how that material got in that state.
I would duplicate the Aluminum Brushed from the material library and then change the color to something dark.
However, a dark object on a glaring, white background with a large homogenous light source will crate a high cotrast image that will make it difficult to see the finer surface details.
I reapplied a Aluminum Brushed texture and rotated it 90 degrees, just as you did.
Then simply changed the color to something dark.
For illumination I used an HDRI from HDRI haven:
I rendered these images with the canvas render and also not let them render to completion.
It is possible that these renders look different when using the local, or Cloud render.
