Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Why Can't I Upload Parasolid Files Anymore? Please Help
utekcnc
Message 1 of 16
utekcnc
I've always been able to upload X_T files from one of my customers.   I get a pdf error message every time now.  I have attached a screenshot of it.   These very same files load just fine in Alibre so I don't think they are bad files.  Please help.  Thank you!
Replies (15)
Message 2 of 16
ryan.bales
Autodesk Support
Autodesk Support
Hi @utekcnc,
The issue is listed in the error of of picture you attached:
"Version of the file format is not supported"
Which means exaclty what it says - they are sending you a version of X_T format that is newer than we support in Fusion. Have them or if you can open and work in them in Aibre, down save to an older version and you should be fine.
Ryan Bales
Fusion 360 Product Support
Message 3 of 16
utekcnc
Ok, thank you
Message 4 of 16
utekcnc
I'm actually a bit confused....I've always been able to open these.  Are there older and newer versions of parasolid files?  I thought a parasolid x_t file was the same no matter what.
Message 5 of 16
ryan.bales
Autodesk Support
Autodesk Support
Its tricky to find but yes there are different versions of Parasolid files. Cadexchanger has some good information on this and can switch format versions. https://cadexchanger.com/parasolid
Ryan Bales
Message 6 of 16
ryan.bales
Autodesk Support
Autodesk Support
The development team asked me to get a sample from you so we can test the new - forthcoming - translators slated or the April update. Would this be possible?
Ryan Bales
Message 7 of 16
utekcnc
Yes, I cannot post it here on the forum due to a NDA, but I can email you one of the files.   What is your email or does it work to PM files?
Message 8 of 16
ryan.bales
Autodesk Support
Autodesk Support
Just send it to my autodesk email - [email protected]
Ryan Bales
Message 9 of 16
Sam_Bachell
Community Visitor
Community Visitor
I'm having this issue also with .x_t files from NX. Is there an ETA to get support for the latest version of these files in Fusion?
Message 10 of 16
produktion2PZ3GF
Also having issues, any news?
Message 11 of 16
TheCADWhisperer
@produktion2PZ3GF
What version of Parasolid? Can you zip and Attach your file here?
You can determine the Parasolid version by opening the file in Notepad or other text editor...
Can you request an earlier version from the source?
You must have a paid commercial license of Fusion, not the free personal license.
Message 12 of 16
ryan.bales
Autodesk Support
Autodesk Support
Its also possible the version is newer than what we support. I'd have to check on what version is currently supported.
Ryan Bales
Message 13 of 16
produktion2PZ3GF
My knowledge about cad-files is limited. Here it doesn't say parasolid but it's an X_T file.
I can't upload the file due to confidentiality.
Message 14 of 16
TheCADWhisperer
*.x_t is Parasolid (see second line in your screen capture).
Can you request an earlier version Parasolid file from the source?
If yes, I would request *.x_b format instead and version 30.
Alternatively, can you request a STEP (*.stp) version file from the source?
If you cannot get different version from the source - then you are out of luck.
(Completely wild guess - you might be able to open current version Parasolid sometime around end of March to mid April).
Message 15 of 16
produktion2PZ3GF
We've been getting the same format from this supplier for years and it has worked with fusion since we started with it over a year ago.
Managed to get an older CAD-program to work so I'll be converting to STEP in there until you get Fusion up to date.
Cheers
Pontus
Message 16 of 16
TheCADWhisperer
We've been getting the same format from this supplier for years…
Format, well yes, but has version of Parasolid format been updated over time?
If you have a working relationship with the source simply request an earlier version of Parasolid format.
