Why can't I constrain a simple hexagon?
I'm trying to better wrap my head around full constraining sketches and I'm running into some trouble. I'm trying to sketch out a very basic hexagon and for the life of me I can't seem to get it full constrained.
Here is a link: https://a360.co/2Hni4DC
The sketch switched to black lines once I set the perpendicular constraint on the construction line, but in the tray to the left it doesn't have the padlock symbol indicating that it is fully constrained.
Thanks for any help.
jhackney1972
You did not say where in your sketch you are placing your polygon center, I did it on the origin.  If you are not using the origin, use my technique plus add sketch dimensions or constraints to the polygon origin and some other fixed location like the model origin.
John Hackney, Retired
Thanks for the response John. That helped solve my problem.
jhackney1972
Please mark your forum question as solved to remove it from the forum list and help others find similar solutions.
