Why can I not edit sketches in older models?
peterguilliatt
peterguilliatt
Why can I not see sketches in older models? I created a new model a few days ago to see if it would allow me to edit the sketch, which it does. Older models simply show a blank page when I try and edit the underlying sketches.
g-andresen
please share such a file
File > export > save as f3d on local drive > attach to post
günther
peterguilliatt
Find a file attached. Thanks.
This file "FIN - Plain Box Interior Measurements v2.f3d" is the one which is having trouble.
This file "EndoscopeTest v1.f3d" is okay.
Marco.Takx
Hi @peterguilliatt,
I don't see any problem.
Your first sketch is empty. It's probably a mistake to finish it before sketching something.
After you use a sketch Fusion 360 turns the visibility Automatically OFF.
By clicking on the eye you can turn the visibility ON again.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
peterguilliatt
I can see all bodies fine. I want to change the size of the box, but can't see the dimensions despite the sketch being visible. See attached picture 20231220_112801.JPG
Another model shown in picture 20231220_112848.JPG shows the dimensions visible.
HughesTooling
As @Marco.Takx mentioned Sketch1 is empty and could be deleted. Only problem is you projected\referenced the origin from sketch1 into sketch2.
Here you can see If I delete sketch1 the only error is the lost projection.
See attached file where I've deleted the empty sketch and fixed the error.
Mark Hughes
Owner, Hughes Tooling
HughesTooling
@peterguilliatt Also please don't attach pictures, just paste them into the message or use the insert photo option.
Mark Hughes
