While working in a sketch settings
wilkinsmarc784
Observer Observer
wilkinsmarc784
Observer
Observer
Is there a way to set the display settings so that I can see other parts of the design when in a sketch? Also, is there a way to "lock" the sketch so I can't rotate it while working in it?
davebYYPCU
While I don’t understand the context,
articles in the browser can be hidden with the eyeball, being a toggle, they can also be visible.
Sketches to be locked, would need more context.  I don’t think you mean fully constrained.
Might help...
wilkinsmarc784
Observer
Observer
Thank you for responding.
As far as being able to see the rest of the design while in sketch, here is
an example.
This what I would see while not in sketch mode.
[image: image.png]
This is what I see when in sketch mode
[image: image.png]
I'd like to be able to see the components I'm sketching around.
On the second question.
I can see the true perspective of Top view. But when I move around the
sketch rotates. I'd like to be able to lock in Top, Bottom, Right, Left
views.
[image: image.png]
Lock the sketch to prevent this
[image: image.png]
Thank you
davebYYPCU
None the wiser,
your picture references - not sure how you did that.
if you are editing a sketch early in history, then you can not see anything to the right of its position in the timeline while editing.  Make a new sketch at the end of the timeline to fix that problem.
Might help...
wilkinsmarc784
Observer
Observer
Ah, that makes sense!
