Where to send errors
CADZLTM4
CADZLTM4
RajkumarIlanchelian
@CADZLTM4 Feel free to post it here with the details. I can follow up after that.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
CADZLTM4
It's that error screenshot attached above and I was making a flat pattern of an existing component so I could use it in a drawing. The flat pattern still was created and it didn't hinder me at all.
RajkumarIlanchelian
@CADZLTM4 Ok. Thanks. This is not repeatable I assume.
Autodesk Fusion
Join Fusion Insider
CADZLTM4
It happens each time I do a flat pattern in that file. Cant attach it
because its a work project sadly.
TheCADWhisperer
@CADZLTM4
Can you reproduce the issue in a dummy file?
Does your geometry adhere to the 4 basic rules of sheetmetal? (There are more than 4 but usually issues can be traced to the basic 4.)
