whenever I try to move the object its getting freeze
hi
I am new to fusion and working on a project watch winding machine,
as shown in the image whenever I try to move the watch stand to the case it's not allowing me to move and fusion getting freeze for a couple of minutes I don't know how to solve this.
pls help me solve this I am planning to print this due to the error I cant able to finalize the design
wmhazzard
Please attach an f3d file of your model.
I have attache the F3D file with this
wmhazzard
I don't know the exact cause of your problem but there are many warnings in your timeline that you need to address and fix as when they go unfixed they can cause problems like this. Also moving components into place is not good practice, either build the components in the place that they need to be or use a joint to place the components. The problem that you are having might come from one of the yellow warnings along with one of the previous moves. It could stem from one of the gears as they have a large number of faces which need many calculations. The large gear is also interfering with the housing.
jeff_strater
The problem is the use of Contact Set.  Contact is a very compute-intensive operation - I don't recommend it for complex geometry, or for lots of components/bodies.  If you disable Contacts, you can move this component just fine.
Jeff Strater
Engineering Director
thanks a lot its really works
you save me the day
thanks for your help and Hint
noted and try to clear the errors
