When I upload a parasolid.x_t file, I can't edit it in Fusion
johnnycardosoKVDD9
Message 1 of 8
johnnycardosoKVDD9
Steps to reproduce
When I upload a .x_t file, I can't edit it in Fusion. It opens in the browser and if I try to open from the browser with the desktop connector, it directs to an empty fusion file. The same is not true of iges files, for example.
Expected results
I expected to upload the file so I could edit it. But the box with editing or preview does not appear.
Actual results
It only opens in the browser .
URL where issue occurs
Browser
Microsoft Edge
OS
Windows
Replies (7)
Message 2 of 8
jeff_strater
what kind of license do you have?  I believe that parasolid translation is not supported with a Personal license.  Untranslated files will behave as you describe.
Jeff Strater
Engineering Director
Message 3 of 8
johnnycardosoKVDD9
Yes, i have a Personal license. I haven't found anything about this personal license restriction. 😐
Why does the educational license allow this type of file?
Message 4 of 8
TheCADWhisperer
https://help.autodesk.com/view/fusion360/ENU/?guid=TPD-SUPPORTED-FILE-FORMATS
Gives the kids a chance to learn with full functional software so that they know what to specify when finished with schooling.
Message 5 of 8
jeff_strater
Here is the announcement of the changes to the Personal version, from Sept 2020.  changes-to-fusion-360-for-personal-use .  Formats supported for Personal users are:
Jeff Strater
Message 6 of 8
daniep790
Observer
Observer
May I ask whether anyone has found a good workaround for getting some x_t files into an acceptable format for work with it in Fusion while using the personal license?
Message 7 of 8
TheCADWhisperer
@daniep790
Are you specifically asking Autodesk how to circumvent the Software License for personal use that you agreed to?
Message 8 of 8
daniep790
Observer
Observer
No, as you state, that is the license that we agree to, and though such shortcomings are sometimes a bit annoying, I do appreciate the opportunity to play with it free of charge for my personal use.  As such I can also not complain about what I do not pay for.  Still I am hoping that someone at least found a way to work with these Parasolid files.  Something like a dependable way to convert them to a format which would be accepted by our personal license Fusion360 SW.  I have tried a few free conversion tools, but they all failed right away with a simple sample file, so it doesn't seem very promising to find a simple way to get them  editable.
