When exporting to STEP file, all Body names and Folders are lost
pangelotti
Message 1 of 9
pangelotti
Hello, When I export to a STEP file, all of the Names for each Body are gone, and the individual folders are gone as well. It is just one folder with a list of Bodies in numerical order. Is there a way to export to a STEP file and maintain the body names and the folders they were in?
Replies (8)
Message 2 of 9
jhackney1972
If your assembly is composed of Components, a STEP file export will maintain the names of the Components.  I am not quite sure what you mean by Folder?
John Hackney, Retired
Message 3 of 9
pangelotti
Here's a screenshot from the Original Project File
Screen Shot 2021-11-15 at 2.45.30 PM.pngAnd this if from the exported STEP file
Message 4 of 9
pangelotti
It looks like from your answer, I need to put the bodies into components.  Is that correct?  Sorry I am new at this, do you have any advice?
Message 5 of 9
pangelotti
Update.  I created components, and those Component Names transferred.  But the Bodies that were named under those components are generically named Body 1, Body 2 and so on.
Message 6 of 9
pangelotti
Is there any way to retain those Body names when you export to a STEP file?
Message 7 of 9
jhackney1972
I do not know anyway of retaining the Bodies names in the STEP file export.  I see what you are talking about when you mention Folders.  Bodies are grouped using folders and as far as I know these folders are also not copies when exporting to a STEP file.
Correction: The Body folder is retained, under the component, but the Body names are lost.  Below is a screen capture from a STEP file exported from a Fusion 360 file containing Components.
Message 8 of 9
TheCADWhisperer
You did not do this correctly.
Attach your file here and I will demonstrate correct technique.
File>Export your *.f3d file to your local drive and then Attach it here to a Reply?
Message 9 of 9
bpetersen9BTH4
Any updates on this?
are you able to provide an example of exporting to a .step file and keeping the bodies names?
