Whats up with my file menu?
tmash1222
Message 1 of 10
tmash1222
When i bring up the file browser this happens and i am unable to interact with any of the menu
I have done each of the following multiple times:
Cleared cache
Uninstalled and reinstalled
Rebooted PC
not sure why this keeps happening
Replies (9)
Message 2 of 10
tmash1222
data Panel is the proper term i should be using
Message 3 of 10
jhackney1972
You may have tried some of the solutions in this web article but some you may not.  I recommend as a last resort try the Manual Uninstall and Reinstall at the bottom of the page.  First though, try the Reset Default Layout option.
John Hackney, Retired
Message 4 of 10
tmash1222
I got around to doing the graphics driver un and reinstallation, so far it is working, for reference i have a K5100M card in an HP Zbook
Message 5 of 10
tmash1222
i revise that did not work it is still an issue for 75%of the time
Message 6 of 10
FrodoLoggins
Same for me. Reinstalling/repairing Fusion, resetting the layout, and even buying multiple brand new computers hasn't worked. Hopefully future updates will be tested before releasing to the public.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Message 7 of 10
tmash1222
yea dead in the water here and i cant make new programs. going to un and reinstall again to see if i can get it to work just once today just tried 5 times restarting with no luck.
what pc and hardware are you running?
Message 8 of 10
tmash1222
so before performing the nuclear option. I opened a second instance of fusion and the second instance had a functional data panel.. going to roll with it for now. no clue why this is happening, i feel like this update still has some bedbugs
Message 9 of 10
tmash1222
other pc same issue and different hardware
Message 10 of 10
tmash1222
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Dat...
I am trying to rectify it through the available info but the like is dead
https://knowledge.autodesk.com/article/The-Data-Panel-is-offset-in-Fusion-360
 I am doing my due diligence but to no avail
