Message 1 of 13
I am running a 2d Pocket using a circle created with the circle tool. The simulation does not show the slight flat spot on the outer edge that the G1 linear movement creates.
What setting could cause the 2D pocket tool path to add a linear movement and not make the circle perfect? besides this linear movement the circle is very nice. You can see the linear movement on line 69 and 93 as two examples in the middle of the circle.
