Weird glitch when doing circular pattern.
marvin.fachtner
Observer Observer
marvin.fachtner
Observer
Observer
Hello Fusion360 Community!
I have a weird glitch that I cannot solve.
First, when I am creating a hole in my part, it creates a tiny glitch, which can be seen here:Screenshot 2022-12-13 115607.png
But this isn't even the bigger problem. Or it solves itself when I do the next step.
The next step is doing a circular pattern to get more holes. When I do this, this glitch appears:
I have already tried a lot of different things, but nothing helps.
The .f3d file can be found down below. I would really appreciate the help.
TheCADWhisperer
If it were my design I would:
1. Fully define all sketches - no blue lines, arcs or white dots.
2. I would not have duplicated sketch geometry in Sketch40.
Pattern Features rather than sketch elements...
3. If you Edit Revolve54 do you get any errors?
When I start to add missing dimensions to try to decipher the true Design Intent - the dimensions do not make logical sense?
I recommend starting over from scratch and Attaching your new file here after each and every arc or line.
A clean logical fully defined sketch is critical to achieving predictable robust geometry.
jeff_strater
these are graphics glitches.  Your design itself is fine.  You can fix this using Display Detail Control, as in the screencast:  https://knowledge.autodesk.com/community/screencast/d65038c1-50e8-4ca9-b839-63acd738316e
Jeff Strater
Engineering Director
marvin.fachtner
Observer
Observer
This instantly worked. Thanks!
