Weights for vertices
IDIMITRIOUD883D
Message 1 of 10
IDIMITRIOUD883D
How easy is to calculate the weights for the vertices in a T mesh after the insertion process ?
Replies (9)
Message 2 of 10
TrippyLighting
Since when do vertices have weight?
Message 3 of 10
IDIMITRIOUD883D
Sorry. I meant control points!
Message 4 of 10
TrippyLighting
When you import a quad mesh, the vertices of the imported mesh become the control point otherwise also called CVs or control vertices. But, again, that pertains only to a quad mesh. that you want to convert into a T-Spline
Message 5 of 10
IDIMITRIOUD883D
So suppose  i have a quad mesh, how can i find the assossiated weights?
Message 6 of 10
TrippyLighting
Weights, or Vertices ?
Message 7 of 10
IDIMITRIOUD883D
i mean weights of control points (xi,yi,zi,wi) .
Message 8 of 10
TrippyLighting
You cannot access those.
Why would you need that ?
Can you provide a graphic example ?
Message 9 of 10
IDIMITRIOUD883D
i need them for educational reasons.
is it possible to export them from a file (stl,step, etc)?
Message 10 of 10
TrippyLighting
.stl files contain only triangular meshes without vertex or face normals or any other attribute. They certainly don't contain weights.
STEP files usually don't contain mesh data.
The vertices in the mesh file formats I am familiar with (.obj .fbx to name a few) as far as I know do not contain any weights.
I don't know if T-Splines carry any weight information on vertices (that is proprietary info) , but if they do,  I know of no way to extract that from any file format that contains T-Splines.
