@paul.clauss wrote:
Hi @Anonymous
Thanks for sharing the file. I had no errors downloading, uploading, and then sharing a link of the file. I've sent you a direct message with the link. It seems like something may have gone wrong during the initial upload process - does everything work properly if you download a new copy of the file and re-upload it to Fusion 360?
Downloading the archive and reuploading did fix the link sharing, but this hack nukes the revision history. I would like to know how resolve the issue with the original design file. I have tried moving components around and resaving to force a change commit that would in turn force the viewer to rebuild the file, but this does not seem force this problem to go away.
1. Is a permanent issue with the file and thus I need to make a new branch of sorts by essentially copy and pasting each time I need to do a review?
2. Is there a real solution or some type of debug tool that can tell me what is causing this?
3. Or is the only possible solution to just reupload the design file and hope that the viewer generates without problems going forward?
