We want to use 2000x1000 paper instead of the A0or A1
serkanleblebiciVYZ4G
Hi Guys, It is very important for the biggest size for the template border. Because we can sometimes use the big size laser-cutting parts. We have to send laser cutting dwg or dxf format file on as 1:1 scale. However, we do not use the 1200mm above for big parts it is very important and the Fusion360 team has to solve this problem urgently. Any suggestion is not accepted as PDF or any different solution for this issue. Fusion360 team sometimes gives ridiculous advice. They to be attention for this subject.
sutherland-
Hi @serkanleblebiciVYZ4G
Fusion 360 does not support custom drawing sheet sizes, unfortunately.
One workaround (not tested!) could be to try scaling the exported PDF if the native PDF ratio is the same.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
ClintBrown3D
We have not yet built a custom sheet size feature, this is on our roadmap. For large DXF exports, I’d suggest exporting the DXF directly from the modelling environment.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
As always, we take all customer requests seriously and your request for custom sheet sizes has been logged in our feature request database. We use this data to help us prioritise the features that we build.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
