Warning: No passes to link. Warning: Empty toolpath.
nikkiY58Q3
nikkiY58Q3
I've created my first cam setup. I want to put a chamfer on a piece of 25.4mm steel rod with a ball endmill. Very little material needs to be removed. I can't decipher the two warnings. I haven't a clue where to look for the problem. No video really explains the issue. Should I post a file or something? Thanks.
seth.madore
Hi!
When posting to the forums, a file does a lot more for us than a description. Unless it's under NDA, please share the file here:
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
