View Manipulation
View Manipulation
cr8n
View Manipulation
cr8n
This is NOT a support request but I couldn't find the old feature recommendation forum anymore.
Nearly every 3d modelling and slicing software uses the right mouse button to orbit.  It would be super helpful if Autodesk would adopt that method as well.  I know orbiting is already easy but as a user that requires multiple softwares in the work flow, it is frustrating at times to accidently right click to orbit and end up with a random touch screen command.
Just a suggestion, I know you guys have been great about listening to customers on this software over the last few years.
lance.carocci
Fusion already supports a number of canvas navigation layouts, including some designed to replicate other common software. The Tinkercad layout, for example, uses a RMB-hold to orbit the canvas. You can change these from the General section of Preferences, or under Help > Quick Setup.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
cr8n
I had no idea that setting was there!  Thank you.
