View Cube Lock Up Bug
2herds
Message 1 of 10
2herds
Just wanted to post the View Cube is again locking up. All I had was a 20x20x20 cube in the Model and the cube locked up.
Version 2.0.5119
Using Macbook Pro OS-Mojave
Replies (9)
Message 2 of 10
masa.minohara
Hi @2herds,
Thank you for posting in the forum! I don't have a Mac computer with me and cannot test right now but would you mind recording a screencast of the steps to cause Fusion to hang so I will be able to test as soon as I get back to the office?
Also, if the issue is specific to one design, please share a public link to the design with me.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 10
2herds
I started a fresh model of a box 50x50x90 mm starting in the XY plane. Then made a tapped hole in it, just anywhere, just to be doing something, so far View Cube still working.
Made an off-set plane -20mm off to one side, then View Cube locked up.
Opened mail to respond to you here in, then went back to Fusion and now View Cube is again working?????
Message 4 of 10
2herds
Will add another lock up. Was making a sketch XY plane and then made 2 construction lines one horizontal 38.1mm and at its end a 10mm vertical construction line. Stopped Sketch and View Cube locked up.
Message 5 of 10
2herds
Was making a simple sketch and it locked up again. I hope I did the link to the file ok, 2nd time for me.
https://a360.co/2CAN3qU
Message 6 of 10
2herds
Wrong file, sorry.
Message 7 of 10
2herds
Tried again with correct file - I hope.
https://a360.co/2TdNEEG
Message 8 of 10
masa.minohara
Hi @2herds,
Thank you for sharing the file with me! I'll try to reproduce the issue and look into it.
Just to check, does Fusion hang when you are using View Cube in any other files?
Masanobu Minohara
Message 9 of 10
2herds
Fusion's View Cube has locked up on 2 fresh files, so I feel a file issue is not a problem. The last file posted was fresh and the 1st operation was to (1) sketch, (2) picked XY plane, (3) construction line horizontal to left of origin, (4) at end of line went vertical with second construction line, .... locked up view cube.Screen Shot 2018-12-27 at 7.59.39 AM.png
Message 10 of 10
masa.minohara
Hi @2herds,
Thank you for your response! I'll check with the internal folks and circle back here as soon as I have more information.
Masanobu Minohara
