permissions associated with C:\Users\<user>\AppData\Local.
Hi all,
how do I get permissions associated with  C:\Users\<user>\AppData\Local?
I have winError 3 and can´t download fusion 360 because of missing path - localappdata.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Can you try the steps documented here to fix the problem?
Also, try running as administrator when installing Fusion (right-click the installer, select Run as Admin). The AppData location requires Admin level permissions to write to.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Hi James,
first, I right click the installer. For a very short time I saw a black box and didn´t know if or what to write. So I didn´t do anything exept waiting. Than after a short time I get the Error 3 hint again.
Second,  I tried to deinstallate fusion 360.  But I never tried it before, so I don´t have the possibility do deinstall it.
So what else can I do?
Best...
