View cube disappears
lbatemanBUCM5
lbatemanBUCM5
The view cube disappears mid way through working in design. The only way I can get it back is to restart fusion.
fusion version- 2.0.20981
macos-15.2
TimelesslyTiredYouth
Hi @lbatemanBUCM5
  • Toggle ViewCube Visibility: Use the shortcut Shift + Command + C to toggle the ViewCube on and off. Sometimes, it refreshes the UI.
  • Graphics Driver Issues: Check if your Mac's graphics drivers are updated or compatible. Fusion 360 can struggle with outdated drivers.
  • Reset Preferences: In Fusion 360, go to Help > Reset Fusion 360 Settings to revert to default settings. It might resolve any hidden UI issues.
  • Disable Hardware Acceleration: In Preferences > General > Graphics, turn off Hardware Acceleration. This reduces strain on your GPU and can fix visual bugs.
  • Reinstall Fusion 360: If none of the above work, uninstall and reinstall the software to resolve potential corruption.
Just a few suggestions that were once suggested to me in the past with this issue, hope it helps!
Happy New Year Regards!
Ricky🤣
Has this started since the latest update or is this an issue that you've had for a while?
colonarturo24
I've been struggling with this issue. For me, it mainly happens when starting fusion. Here are 2 settings that i changed that solved the issue for me. Hope this helps. Ill also be sharing this in other topics to help others because this seems to be a common problem.
