Using F360 to test handmade wire gears?
sotooleAC4DP
sotooleAC4DP
Hi F360 folks:
I'm trying to make a moving wire sculpture in real life. This use shandmade gears made from 12 guage wire. Getting these mechanisms to work together can be tough.
I'm trying to figure out if I could use F360 to model the *actual* way that these gears would interact - so I could make them work in F 360 and then, once all looks good in F360, I would make the gears in real life.
Question: Would F360 be able to show me the real-world motion of wire gears that I create in F360?  For example, once i make the gears in F360 and then join them, is F360 smart enough to show real-world physics and thus show me whether a 23 tooth gear with weird spacing would successfully turn a 17 tooth gear with weird spacing? Or, does it just make the gears rotate, but not in any real world way?
for an example of the sort of thing I want to test in F360 see:
https://youtu.be/My2DxFE8rjo
Thanks!
-=shar
innovatenate
Autodesk Support
Autodesk Support
Check out this other discussion below and let me know if it helps.
https://forums.autodesk.com/t5/fusion-360-design-validate/how-to-animate-gears/td-p/5571139
Using Motion Links to create a rotation ratio  between two joints for each gear. You may also possibly use Motion Study.
I hope that helps to get you pointed in the right direction. Let me know if you have any questions.
Nathan Chandler
Principal Specialist
