Using AutoCAD ONLY To Produce The STL 3D Printing File
omorah
Message 1 of 8
omorah
Hello folks, I am just reading all about 3D Printing technology and am planning on acquiring a 3D printer.
About the software, I found out that Fusion 360 is recommended for producing a 3D printing file/model/object.
My question is, if AutoCAD can produce a STL file for the printer, can I solely use AutoCAD to produce my solid models exported 3D printing files? I am already experienced in AutoCAD 3D Modeling, so I won't have to learn the use of Fusion 360.
Cheers
Replies (7)
Message 2 of 8
seth.madore
AutoCAD is not Fusion 360, they are different software packages. Fusion 360 is a very solid tool for creating prismatic solid models, and somewhat capable of free-flowing "artsy" type stuff. If you're wanting to produce artistic/organic elements such as animals, flowers mythical beasts, video game armor/weapons, you'd likely be better served by Blender or other similar design software.
Of course, there will likely be other bits of advice from other more experienced users, and I would certainly defer to their expertise.
Seth Madore
Message 3 of 8
omorah
Thank you for your reply.
Nope, I don't plan on producing artistic/organic models.
Yes, I know "AutoCAD is not Fusion 360". I had asked if I "can I solely use AutoCAD" for the STL (final) file. I am proficient in AutoCAD 3D modeling which produces models and exports to STL file.
I have not purchased the printer yet, just getting myself ready.
Cheers
Message 4 of 8
g-andresen
Current slicers work with STL and currently increasingly with 3MF.
If you can create one of these formats in ACAD it should work.
günther
Message 5 of 8
omorah
Yes, I created a simple 3D model in AutoCAD, exported it in STL format, then imported it into Slicer software; it looked ok just like when I produced it in AutoCAD.
Thanks for the reply.
Cheers
Message 6 of 8
TheCADWhisperer
@omorah
Yes.  Geometry is geometry.
You can use AutoCAD or any CAD program to create your geometry.
In AutoCAD set facetres=2000 for high resolution (and there is another setting).
Run the command stlout...
Message 7 of 8
omorah
Thank you for the information!
Message 8 of 8
omorah
