Use power or multiplication with users parameters
remy.muller
Message 1 of 11
remy.muller
Hello the community,
I'm disapointed ! I want to create an user parameters with power on a "model parameters" (d1)  but I can't.
I try this expression :
Add User parameters >
Unit : mm
Expression : 10 ^2
and it works !
But I would like to use this with model parameters :
Unit : mm
Expression : d1 ^2
And it doesn't work !
Anybody have an idea ?
Rémy
Replies (10)
Message 2 of 11
HughesTooling
You need to match the units, the input type needs to be unitless so (d1/mm)^2 will work. If you don't cancel the units the output would be square mm so you'd need to select an area unit type for the parameter.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 11
Phil.E
The reason you can square 10 in your example is it produces a unitless result, which is given the units "mm" by the parameter. So 10^2 = 100, and the value of the parameter is shown as 100, with mm units. It is a linear value.
When you try to square d1, it already has mm units. The result is square mm which conflicts with your chosen units of "mm". d1 squared is an area value.
Assuming you just want the linear result (mm) and not area (mm^2), you just need to eliminate the squaring of "mm".
If that's what you need, try this:
If not, please let me know, or if you have any other questions of course just ask!
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 4 of 11
remy.muller
Thanks a lot Mark and Phil ! I understand and It works 😃
Thank you for your rapidity !
Message 5 of 11
edburns000
@Phil.E Powers handle units correctly but sqrt() or ^0.5 do not!
To do some simple length-of-hypotenuse sums I am having to convert dimensionless quantities before calculating, i.e. sqrt(((width/1mm)^2)/2).  Not the worst workaround to implement if you know how to handle it, but the unit handling seems half-baked...
Message 6 of 11
Phil.E
Referring to the product documentation, sqrt is handled by: unit^1/2
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-76272551-3275-46C4-AE4D-10D58B408C20
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 7 of 11
edburns000
@Phil.E
Any idea why I can't enter "sqrt(2mm^2)" as a valid expression then? (sqrt(2^2) is valid) Am I missing something obvious?!
Message 8 of 11
Phil.E
2mm squared is an area measurement. You cannot take the sqrt of an area.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 9 of 11
edburns000
In the example above, if length^2 = area (as it should) and length^3 = volume, then sqrt(area) = area^1/2 = length and cube-root(volume) = volume^1/3 = length
It's a perfectly valid calculation, and mathematically correct - if the square of a number squares the units, then sqrt of a number should sqrt the units.
I might want to calculate the length of the sides of a square face from its area. Or calculating the length of a hypotenuse on a triangle:
sqrt(side1[mm]^2 + side2[mm]^2) = side3
sqrt(length^2) = length
Message 10 of 11
Phil.E
You are correct, Fusion should allow you to use unit measures. At this time you must strip units out before using sqrt.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 11 of 11
You can divide it out.
