Upload in Progress error when shutting down
copes6YABD
Observer Observer
copes6YABD
Observer
Observer
This has been going on for 5 days now. Had upload get stuck (I assume) or hours...
vinayak_dhame
Hi @copes6YABD ,
Please follow the below steps to resolve the issue:
Use a text command to remove the Upload Queue
  1. From the File menu, open Show Text Commands (How to show / hide Text Commands in Fusion).
  2. Enter the following text command. This cancels all ongoing uploads and creates a backup of all the uploads in a local folder.
Fusion.CancelUploads
Note: Drawings files (.f2d) that are backed up will not be able to be opened once reuploaded into Fusion, as they cannot be reassociated with the original solid file.
  1. Find the backups in the following locations:
    • Windows: C:\Users\***\AppData\Local\Autodesk\Autodesk Fusion 360\Unique ID\UploadsBackup folder.
    • macOS: Macintosh HD > Users > *** > Library > Application Support > Autodesk > Autodesk Fusion 360 > Unique ID > UploadsBackup folder.
  2. If creating the backup fails, use the following alternative text command.
Warning: This will cancel the upload and not create a backup.
Fusion.CancelUploads/force
Let us know if this helps.
If my answer helped, please 'Accept Solution'
Vinayak Dhame
Autodesk Fusion
