Update stops at 3%
Update stops at 3%
jezek.jaroslav
Update stops at 3%
jezek.jaroslav
I have active update download, but it's stuck on 3% for more than hour.
Is there something I can do to download the update?
Restart fusion is not fixing the issue 🙂
JJ
Rafal.Chlod
Autodesk Support
Autodesk Support
Hi @jezek.jaroslav, thanks for posting.
We can try the following:
  1. You can try to update Fusion 360 manually by using this link. Close the program and reinstall it with the downloaded file (it should start the download process automatically).
  2. Alternatively, if the manual update will not help, use the steps from this article: How to perform an automatic clean uninstall of Autodesk Fusion 360.
If my answer helped you, please click Accept Solution. Thanks!
Rafał Chłód
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
jezek.jaroslav
Hi Rafal, the downloaded file helped. Thanks
JJ
