Update/Installation Errno 0
Fusion 360 started to fail its automatic updates, and in order to solve the issue I attempted to uninstall and reinstall the program. The reinstallation is also failing, citing "<urlopen error [Errno 0] Error> and stops the installation. See log file attached. At this point, I cannot even get Fusion back on to the machine.
dsouzasujay
Hi @Anonymous ,
 I can see you are using a proxy server. Can you please try to install Fusion 360 by removing the proxy? Or let us know what the proxy is used for?
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
The proxy is a company managed element of our devices, and the solution ended up being to temporarily disable the antivirus software. Fusion installed properly and now updates properly as well. I am a little confused as to why this was not an issue on my other machine that uses the exact same proxy and antivirus, but at least it's working now!
Thanks @dsouzasujay !
dsouzasujay
Hi @Anonymous ,
I'm not sure what might have caused this issue.
But good to know Fusion 360 is back and it Auto-updates.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
