Update failed to complete
dbecker30
dbecker30
What do i need to do next.  Been getting this message for like 2 days now.
dooyoul_chung
Hi @dbecker30
It would be helped review your case with Fusion 360 log file. Could you please share the log files with below guided steps?
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
Dooyoul.
dbecker30
There
dooyoul_chung
Thank you for sharing log file.
Looks like another streamer.exe process is running.
1. Close Fusion360
2. Open task manager & close streamer.exe (or Fusion360.exe) if running from process.
3. Launch Fusion360
or try open Fusion with just reboot your PC.
Dooyoul.
dbecker30
Just tried all that and i still have failed to update message.
dooyoul_chung
@dbecker30
Unfortunately, not able to pinpoint issue immediately. Wondering what error message you are received for update failure? Based on you share log file, try to upgrade from 2.0.12376(20220204233047) to 2.0.12392(20220216104621) but looks like process been bypassed to update.
If you are currently in the same status, please try with below step to see you can get updated version 2.0.12392. Below step works when you have only one release of Fusion. (means no side by side installation with insider version).
1. Remove %localappdata%\Autodesk\webdeploy\meta\registry
2. Execute %localappdata%\Autodesk\webdeploy\meta\streamer\streamer.bat
Hope this helps.
Dooyoul
