update error
update error
update error
Hi
Every time I start Fusion 360 I get a message "down loading update" then almost immediately an update error.
In the log file there are a few lines with win error 2 can't find file (followed by a file path). Looking at just one of these, when I follow the file path in file explorer, the file is present.
I am on a desk top using Windows 10.
Should I re-install Fusion 360  or could it eventfully sort it's self out? Is re-installing likely to cause any issues.
Nigel
innovatenate
Autodesk Support
Autodesk Support
Try killing rogue background processes related to Fusion 360:
1. Opening Task Manager (CTRL + SHIFT + ESC)
2. In the Details or Processes tab, find any process named Fusion360.exe and/or adcefewebbrowser.exe and select it
3. Manually end the Task using the End Task command
You could als try restarting your computer to clear any odd permissions issues?
Otherwise, try clean uninstalling Fusion 360 (select No to keep your cached data) and re-installing.
I hope this helps!
Nathan Chandler
Principal Specialist
Hi
Thanks for your reply.
After doing a clean un-instal fusion 360 will not re-install.
During the streaming process I get a "permissions problem".
I have spent a great deal of time following recommendations to no avail.
Unfortunately, I just don't have the time to try and sort this out, I just
don't know enough about computing.
So fustratingly I'm having to look to other cad packages for now.
Thanks again
Here's some more information.
As said in my previous message, during streaming on installing Fusion 360 I get a "permissions problem" message.
The installation log is massive but near the bottom I see a "Permissions error 13 Permission denied". and a file path ---- AppData----FusionLauncher.exe. However, in the actual file there is an application "Fusion 360" but no "FusionLauncher" application.
Hopefully this info will help towards a solution, I would really like to get this resolved but for now available time is a problem.
innovatenate
Autodesk Support
Autodesk Support
Can you share the installation log file?
My guess is that the streamer is looking for a file that may not be there or has been locked by another process. Did you try restarting the computer or temporarily disabling anti-virus software to see if it helps?
The Fusion360.exe and the FusionLauncher.exe are stored in separate sub-directories (not the same directory) in:
C:\Users\***\AppData\Local\Autodesk\webdeploy\production\
If you you see the Fusion360.exe, then you're in the wrong directory to find the FusionLauncher.exe.
The file could locked due to a 3rd party application like anti-virus software. One trick to diagnose interferrence from backgorund applications is to start Windows in Safe Mode (with networking).
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Dia...
You may have to temporarily disable anti-virus separately. Another option may be to add an exception in your anti-virus software's settings. See teh below link for tips on how to do this.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Con...
Finally, you can try manually removing all files related to Fusion 360 (perhaps the automatic clean uninstall is not removing them all). See the below instructions.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
I hope this helps. Please let me know if you have any questions. I am happy to help.
Nathan Chandler
innovatenate
Autodesk Support
Autodesk Support
One other thing that may be worth trying:
When you go to run the installer, try right clicking on the file and select Run as Administrator
Nathan Chandler
Hi
Thanks to your generous help I am back up and running. It's been frustrating but because of your help I have learnt allot.
I ran in Windows safe mode and left the anti-virus running and Fusion 360 installed and ran without any problems. As best as I can make out the problem seems to have been to do with Windows Security Service which appears to be disabled in the Windows Safe Mode.
FYI - Prior to this I had tried to install Fusion with the anti-virus turned off but got the same permissions error.
I am happy to share the Fusion Log if it's still of interest, what's the best way to do this? it's nearly 5Mb.
Thanks again, so very much appreciated, Fusion 360 is great.
Regards
John
