Unwanted selection of old geometry
nvdwildenberg
Message 1 of 13
nvdwildenberg
Hi everyone,
A newbee question here.
I imported a stp file and needed to clean it up, basicly redo everything.
Started a new sketch on a face of the old model and made the sketch.
If I now want to mirror it or extrude it or whatever, it snaps to the old geometry and/or faces from the old model as well.
Could not find a way to turn of the old stuff, because it seems to be part of the face I'm working on.
Drives me nuts here, and is probably a new users issue.
Could someone please explane how to avoid these unwanted snaps?
Thanks a million.
Replies (12)
Message 2 of 13
g-andresen
please share your design and mark the relevant sketches and features.
günther
Message 3 of 13
nvdwildenberg
Hello Günther,
Thank you fo your email.
https://a360.co/2EKSsfa
This is the link I hope.
First timer so I hope it works out.
I would like to be able to mirror and than extrude the sketch on sketch8 of
the file.
Also trying to put the link in the forum thread.
Niek
Message 4 of 13
nvdwildenberg
O, this is automaticly done, awsome!
Thanks for all the help.
Merry christmas to you all.
Niek
Message 5 of 13
g-andresen
the link is empty:
share design via data panelshare design via data panel
Important: allow download
günther
Message 6 of 13
nvdwildenberg
Another try.
The troubles are in component 7, sketch8
Hope it works
Message 7 of 13
nvdwildenberg
Emty again then.
Got to mis something here.
Another try
Message 8 of 13
nvdwildenberg
tried it with closed file, with open file, I must be missing something.
Should be easy but not in my case.
Wil research this now.
Message 9 of 13
TheCADWhisperer
File>Export and then Attach your *.f3d file here.
Message 10 of 13
nvdwildenberg
Hi CADWhisperer,
Here it is.
Niek
Message 11 of 13
nvdwildenberg
Solved it!
After searching further in the forum I was able to find out what was happening.
It is almost impossible that I would be the first to have this problem, so several solutions should be on the forum.
The solution was to turn off the "auto project edges on reference" and "auto project geometry on active sketch plane"
This prevents untwanted geometry on the active sketch plane. Probably the auto project edges should be kept turned on.
Don't know if it is possible to put the wanted geometry on a new sketch plane, as it is almost impssible to select only the wanted geometry.
Good chance I have to do it all over again the right way. No problem, I'm on a learning curve here and found out over the last 20 years that you learn a lot from making and then fixing mistakes.
Why I wasn't able to get the public link right isn't clear to me, will have to dig in here as well.
Thanks for the swift reply's to try and help me out, awsome community.
Message 12 of 13
g-andresen
Hi Niek,
1. The irritation with the upload was caused by a project file (f3z) containing 2 f3d files.
The f3z must  be uploaded to the Fusion data panel first and saved.
2. You have already registered the problem with the "autoprojections".
In the screencast, I inserted a sketch in front of the first extrusion and placed a projected (manually) profile of the original part into and then renewed the extrusion. I did the same with another extrusion (at the end of the timeline).
I hope that the SCREEENCAST brings some light into the dark.
I wish you a merry christmas time and all the best for 2020
günther
Message 13 of 13
nvdwildenberg
Many thanks for the quick and clear solution, even in the weekend!
