Unstitch Bug.
- Mute
- Permalink
- Report
When designing a mould tool from a component you need a way to separate the inside from the outside. Sometimes you can use Offset Face set to zero to extract the required faces but I'm working on a small box with over 800 faces and chain selection doesn't work. There are only 8 faces joining the inside and outside so I thought I'd remove those leaving me with 2 shells. The trouble is after deleting or unstitching the 8 faces the 2 shells are still reported a a single body even though they're not touching, this seem wrong. A simple test, draw a cylinder change to the patch workspace and delete the cylindrical face and you'll be left with the 2 end caps as a single body! If you unstitch the 2 caps you can't restitch as they don't touch so surly having them show a single body after deleting the cylindrical face is invalid.
Edit. I did try unstitch then restitch on the 2 shells to see if that would separate them, it didn't go well. Here are the crash reports.
CER_148835999 CER_148831833
Mark
Mark Hughes
Owner, Hughes Tooling
