- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a file which began to exhibit the Unresolved Component error.
As the change log was fairly simple, I can pinpoint this to last nights work. I inserted a linked component. I created a new component. I created three sketches on planes of the linked component and made some extrusions. I deleted the linked component as I did not need or want it in the design any longer. I have done this before in other assemblies and have never seen this error crop up as a result.
Curiously, it is a direct modeling file with no design history. I tried editing the sketches and breaking the links to the projected lines and saving that as a new version. It did not fix the error. Of course, since it is a DM file, there is no option to "redefine sketch planes" which I thought may also be a culprit or tripping things up. Not even an option given the lack of design history, obviously.
I then went through the forums and found discussions regarding backing up the local cache, clearing the local cache with the clean uninstall tool and reinstalling Fusion 360. I completed all of these steps, allowing the clean uninstall tool to delete the local cache during that process. I rebooted in between the steps just in case that might be helpful.
The document is still exhibiting this error.
Curiously enough, as another solution which I have attempted and was recommended in previous threads, if I open an older version from a point well before this presumed work caused this error (in this case 36 hours prior) it opens and does not display the warning. However when I save it as a new file and open that file, it does exhibit the same error. Perplexing.
Point of fact being this seems like a non issue other than presentation of the error. I am not seeing anything missing in the file. That being said, it's the unknown if any downstream effects I would like to avoid.
It seems from a best practices standpoint I should figure out how to eliminate the error.
Another curious factor to me is that the error states saving the file will result in the links to the unresolved components being "lost forever", that seems to not be the case as during the process of breaking the links in the sketches I decided to save a new version and see for myself if this was true. This then seems to not be true, because it keeps throwing the error even after this save. Seemingly more like "remembering forever" behavior, in a contrarian twist.
In the master file that references this component, it now also exhibits this error since the linked file has been updated, which is another confounding aspect and something I would hope is resolved when I can figure out how to fix it in the culprit document.
Thank you for any help you may be able to provide. I am not sure what aid it will be but I have attached a screenshot of the error just in case.
