Unfold and Flat Pattern issues
rhetths
Message 1 of 22
rhetths
I am very familiar with the challenges of creating components ripe for unfolding and flat patterning.  I just created two such components as far as i can tell but they cannot be unfolded or flat patterned.
I have noticed more issues with this function lately, recently i derived a component into another file, deleted the design history, then copied it back into the original file and then it mostly unfolded and flat patterned, which suggests there is a Fusion issue not a user issue.
Refer attached.
Replies (21)
Message 21 of 22
rhetths
If the bend isn't connecting to anything else, if it just floats out there in space, i see no reason not to use the bend command.  In certain circumstances it is the quickest and easiest way to create a bend.  All of my bends need to be flat patterned anyway.  And if a mitered bend is required the bend command is the only way AFAIK.
Message 22 of 22
TheCADWhisperer
@rhetths
Can you post an example?
@rhetths
Can you post example?
Are you familiar with the Machinery's Handbook formulas for calculating Bend Allowance?
I am better at communicating with geometry rather than mere words.
