Under Manufacturing tab selecting Create from Template the template is blank
mike_miller515
mike_miller515
Ever since last update whenever i am in the manufacturing tab and want to perform machining operations, by using my templates, Fusion doesn't display the templates until i select another machining function and fully create a path with it.
Once i've done this in any drawing one time it will display them from then on.
If i open a new drawing and try to manufacture it, it does the same thing. It's very annoying.
seth.madore
You mean this flow?
What I see:
Seth Madore
mike_miller515
No what i mean is when i actually select the template it doesn't show up in the tree. I must open another operation such as drilling etc. and generate a path with it. Then the templates show up in the tree.
mike_miller515
Here is a photo of me selecting the template, then the next photo is the template not being put in the tree.
I won't get to use the templates until i create another operation first.
I see nothing:
after i create a drill operation
seth.madore
ohhhh....
Seth Madore
seth.madore
So, I went through your steps, and this is what I "think" is happening:
1) It creates the toolpath, but the Setup is collapsed.
2) Clicking on this "caret" will open up the folder of "Setup":
 Result:
Seth Madore
mike_miller515
yep that fixed it, my first assumption was that the update messed something up. I should have looked at that first, thank you!
