unable to square a parameter
I set a parameter "clearance" = .1 mm
the following functions don't work:
clearance ^ 2
clearance * clearance
however the following functions do work
clearance * .1
.1 * .1
.1 ^ 2
I have tried this with every named parameter I have and none of them can be squared.  I only want the clearance value stored once so I can't use the working examples.
Any ideas why this won't work?
jeff_strater
units.  The result of clearance * clearance is "mm^2" (a measure of area).  You just need to balance the units by dividing by "1mm" to get "mm" as the units.
Jeff Strater
Engineering Director
