Unable to split a shelled body using a cone surface
zachmoshe
Observer Observer
zachmoshe
Observer
Observer
I'm trying to model a "mushroom-like" object. I created the stem and the top part and shelled them to a body with 5mm walls. I also need to split the top part into two parts which I will later on fit one over the other (I need to place some components inside the mushroom).
I tried to use the split tool to do it but it failed with a "Compute failed" error and I'm not sure what I'm doing wrong...
Here is the f3d file, but I also attach screenshots here as it might be easier..
This is the object itself:
f6XWo
A cross section of the mushroom top and the splitting surface I've created (just revolved a line to create a cone):
1IbW4
Notice that the top of the cone doesn't touch the body. I originally thought that this could be the problem but it didn't help.
When I use the splitting tool I don't check the "extend splitting tools", but get a "Compute Failed".
Any ideas? If I'm doing it wrong - is there any other way that I could split the object? Preferably with a diagonal cut so it's easier to fit together later?
Many thanks!
Zach
g-andresen
please share the file
File > export > save as f3d on local drive > attach to post
günther
zachmoshe
Observer
Observer
thanks! attached now.
g-andresen
try this
günther
zachmoshe
Observer
Observer
perfect! that works!  thanks a lot!
I did it twice to get the two parts as two different components.
