Unable to select holes with the Hole and Thread Note command - again
myerpaul
myerpaul
Since the latest update:  2.0.21487 x86_64
I have issues where the hole and thread note tool will not allow selecting of holes.
Even on drawings made in the new version.
I followed this article:  https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Hole-and-Thread-No...
Holes are modeled in fusion using the hole tool.
I cleared cache and restarted.
Only solution is to recreate the drawing view.  I really do not want to restart some of my drawings just to add a hole note.
myerpaul
NM, I assumed the solution to create a new base view meant starting the drawing over. It turns out simply adding another base view and then deleting it tricks the feature into working again.
