- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In the attached f3d file, I have extruded a cylindrical cut (Extrude38) through the side of a ring shape. The extrusion was made from a fully-defined circle in Sketch6. In the photo, the hole in question is in the upper left.
I am able to select the cylindrical face when not in any tool. As soon as I select the thread tool, I can no longer select that face. Other posts I have found indicated that the only way this should happen is if the face was not extruded from a true circle or had some taper to it. Neither of these problems exists as far as I can tell. Only odd thing, perhaps, is that the sketch is on the flat surface in the lower right, not on a construction plane attached to the ring itself.
I have tried a number of ways of specifying the ends of the hole to get the threading to work. The only success I had was to extrude a hole that extends, not only through the outer edge of the ring but also through the square base section that includes the profile plane. That allows me to thread the part I want but leaves me with an undesired extra hole through the base block. Any attempt to "fill it back in" with a join extrude causes Fusion360 to report an error.
