Unable to open design
sam.vanroy
Observer Observer
sam.vanroy
Observer
Observer
For a while now I've been unable to open a design which had 30 versions to date. Not a single one of the versions opens up. Fusion 360 just gets stuck in loading it and crashes. Very sad affair as a lot of time and effort has gone into the design.
I attached the diagnostics file for good measure. Any idea if there is a way to check and repair broken designs?
RajkumarIlanchelian
@sam.vanroy Thanks for the log files. Would it be possible to invite me into the project with this design? rajDOTkumarDOTilanchelianATautodeskDOTcom
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
RajkumarIlanchelian
@sam.vanroy Per logs I see that you are on 2.0.10806. There was a lie update issue on this build. Can you please re-install Fusion 360 (you dont have to uninstall) and that will take you to the latest version. Not saying that this will solve the problem but it would be good to be on the latest build.
Autodesk Fusion
Join Fusion Insider
