Unable to open .3mf files. What is Fusion Team?
ezra_luna_w
Message 1 of 24
ezra_luna_w
Community Visitor
Community Visitor
I have a 3MF file that I was wanting to open as it should have some parametric features that I need to modify to make a 3D print. When I try to open the file, I get an error message stating that "this file type cannot be opened." I can assure that the file is a valid 3MF file. I did some searching and did not come across anyone having this issue. All pages I can find state that you can easily open a .3mf file in Fusion by just opening it.
I decided to try to save my own 3MF file to see if I can open the resulting file, and when I get to the save dialog box, I am alerted, in bright red text, that "the 3MF file format isn't viewable in Fusion Team." What is Fusion Team? How do I open Fusion so that I am not in Fusion Team? I use Autodesk Fusion Personal (Not for Commercial Use) version as I use it for hobby 3D print designs.
Replies (23)
Message 2 of 24
g-andresen
1. INSERT > Insert mesh
2. Fusion Team
günther
Message 3 of 24
harryweiss2024
Unfortunately i have the same problem with import 3mf. I tryed it with insert mesh but i can`t choose the 3mf file, because its grayed out.
Thanks for help.
Message 4 of 24
g-andresen
please upload such a file
günther
Message 5 of 24
harryweiss2024
Hi!
I can`t import 3mf files to fusion.
Enclosed you will find two screenshots.
Message 6 of 24
g-andresen
What I meant, upload a 3mf file for testing.
günther
Message 7 of 24
harryweiss2024
okay, sorry for understanding.
enclosed you will find it.
Message 8 of 24
kayfes
Community Visitor
Community Visitor
Same problem here any solutions found?
Message 9 of 24
info6TGDP
Community Visitor
Community Visitor
hey,
have the same problem, but could work around it by selecting to the concrete file ending. In my case just selecting .3mf as file extension. Looks like a minor but annoying bug so.
Message 10 of 24
klausKYQW8
Thanks for the solution! It works if only the "3MF" file extension is searched. This is a bug in FUSION !!!!
Message 11 of 24
karina.harper
Autodesk Support
Autodesk Support
@klausKYQW8
I am able to use "open", "upload" and "insert mesh" to import a 3mf file and open it in Fusion. Can you take a screenshot of what you're seeing - which dialog is causing the problem?
Cheers,
Karina
Message 12 of 24
gwwallace
Observer
Observer
The "bug" is: you can "upload" a local .3mf file to the cloud and edit it with Fusion 360, but if you do File Open, from my computer, it fails (file type not supported)
Message 13 of 24
klausKYQW8
Unfortunately, I can only speak for the German Fusion, but I think the problem is the same in the English version.
In German version select: "Netz/Einfügen/Netz einfügen/Select on computer ..." It will open an "Insert-Windows.
in the right lower corner your default Select is "Netzdateien ( *. 3mf, *.obj. *.stl)"
but in the browserwindos in the midle you dont see "*.3mf" files.
But if you select "3MF file ( *. 3mf)" then in the Midle Browserwindows you can see the *.3mf file.
I suspect the file extension "*.3MF" in the default filter.
Message 14 of 24
gwwallace
Observer
Observer
On MacOS you can only upload 3mf to the cloud, not edit it in the local app. I did successfully "insert mesh" from a 3MF though.
I don't understand why I just can't open one from File Open (understanding of course there are some things it can't edit/render).
Message 15 of 24
karina.harper
Autodesk Support
Autodesk Support
Strange. I can do all of the following on my mac (15.5) and PC (Windows 10):
  • File - Open from my computer - select 3mf, it uploads
  • File - Upload
  • Insert Mesh - select 3mf, it uploads
The only issue I noticed was in one session on my PC, the "OK" was be grayed out in the file selection dialog. On restart, it worked as expected.
Mine were all made in Fusion, maybe that is a difference? Here is a sample. Can someone share a sample design they created? Also, what OS are you all on?
Message 16 of 24
klausKYQW8
Dear Karina Harper, Not the file is the problem !!!!! Fusion can open all *.3mf files!
However, only if "3MF" selection box is selected in the selection box for file extensions.
If you have selected the main selection with the possible 3 endings, it is not
possible to select 3MF files!
Solution:
1. Correct the selection error in the file dating filter for the default files. (The correct way)
Or
2. Delete the main selection filter for standard file endings (selection only each)
Conclusion: The file is not the problem, but how fusion deals with the query of the approved
fileendations. (Please take a look at the details in my photos in the last post !!!)
Message 17 of 24
klausKYQW8
Message 18 of 24
karina.harper
Autodesk Support
Autodesk Support
Aha... @klausKYQW8  I can reproduce the Mesh Import issue if I switch Fusion to German. I'll go ahead and report that. (Anyone else seeing this in other languages?)
@gwwallace I am still able to use File - Open and select a .3mf for editing. It opens directly in Fusion as an unsaved design. Do you have any more info on what you're seeing? Can you share the 3mf you are trying to open, or try the one I attached?
Cheers,
Karina
Message 19 of 24
harryweiss2024
I use Mac. Maybe i start my Mac again and Look what happens.
Best wishes
Harry
Message 20 of 24
gwwallace
Observer
Observer
Just tried File Open again on MacOS after the latest upgrade and it worked on the same 3mf file I was trying. Must have been a bug that was fixed.
It opens now instead of saying “unsupported format”.
