Unable to install or Unistall Fusion
suneelmo
suneelmo
SInce last 3-4 days. Saving has become a problem.
  1. I found that my disk space maybe an issue. But i cannot uninstall or install the software.
  2.  How can I change the location of next intsallation ? My other drives have more space.
RajkumarIlanchelian
@suneelmo Unfortunately Fusion today cannot install on another drive other than the C: drive.
1. Can you try to clear out the temp folder location? This is one place where it can quickly add up
2. When you try to uninstall, is it showing you and error? If so can you post the error here?
3. When you launch Fusion if you click on Ctrl+Shift, it should launch the Fusion 360 service utility. If you run the "Repair Fusion 360" from the utility, does that help?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
g-andresen
@suneelmo  schrieb:
  1.  How can I change the location of next intsallation ? My other drives have more space.
This is not possible because the installations are done under users and not under programs.
Günther
suneelmo
Thx Rajkumar.
I changed my disk. Secondly your support guy called me and helped me to re load fusion.
Considering the increased space fusion needs, it is better to make it usable from ANY drive.
Thx for the help.
