Unable to extrude face from body aligned to plane at angle
Cat_Peach
Cat_Peach
Hello Autodesk Community!
I'm having difficulty extruding from a face, on a body which is aligned to a plane at an angle.
I'm working through some laser cutter modelling tutorials, and I'm a bit clueless about what I'm doing wrong.
I can't select the faces of the highlighted shape as a profile for the extrude; once extrude is open I can select the faces of the body as objects for the extrusion; but not as the profile for the extrusion itself.
I've uploaded a brief video, as well as the .f3d file and a screenshot; I hope that my problem makes sense!
Any help would be appreciated! Help me Autodesk Community, you're my only hope!
Thanks!
Pat K
TheCADWhisperer
@Cat_Peach
Are all of your sketches fully defined?
Are there any unresolved issues highlighted in your Timeline?
Does CTRL b (CMD b on Mac) return any errors?
What happens if you Edit Feature on Fillet1?
This face is not planar.  (You can test by attempting to start a New Sketch on the face.
The face is actually a conic.
Cat_Peach
@TheCADWhisperer
Ah! Thank you! I hadn’t spotted that! I’ll have a play and let you know how I get on,
 Can’t thank you enough!
Cat_Peach
Solved: The body wasn't parallel with the plane, and had been rotated into a conical surface. Many thanks!
