Unable to even use the software
weihao_wei
Message 1 of 17
weihao_wei
Blank screen no matter what. At best time I managed to got into the UI and then the software just crashed.
"can't find a solution" is what I got from the crash report.
Software were stable few updates ago and now I can not even ask my manager to renewal it since this is no usable .
So far tried:
Uninstall and reinstall 50 times at least
Restarting PC many times.
Tried updating graphic card driver many times, tried different versions. (RTX4080)
Tried clean install with all hidden folders deleted 10 times.
Tried Registry deletion many times.
Tried every single function on the utility tool.
Replies (16)
Message 2 of 17
RajkumarIlanchelian
@weihao_wei Can you please provide us the log files?
Close Fusion
Go to add/remove programs
Select Autodesk Fusion - Modify
This will launch the Fusion service utility
  1. Run the "Gather system info"
  2. This will generate two zip files
6. We will need the Fusiondoagnosticslogs.zip
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 17
RajkumarIlanchelian
@weihao_wei Can you also try another workflow?
1. On this same machine quickly create another admin account and Install Fusion there and see if it launches successfully?
2. On this current install, if you right click on the launcher and do a "Run as Admin" does it make any difference?
3. Is it possible that a Windows defender settings or firewall block could be stopping the software from running?
Autodesk Fusion
Join Fusion Insider
Message 4 of 17
weihao_wei
I tried, however "Run the "Gather system info"" only activate the program for a split second and then the whole thing just closed down.
Message 5 of 17
RajkumarIlanchelian
@weihao_wei
1. Can you manually collect all three files called out in this article? https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-manually-co...
2. Also I posted another post above with a few other workflow to test out.
Autodesk Fusion
Join Fusion Insider
Message 6 of 17
weihao_wei
Network seemed fine
I tried a different email, personal account
I get passed to the UI, but then it crashed.
report ID is 768642216
maybe the minidump file can help?
Message 7 of 17
RajkumarIlanchelian
@weihao_wei Can you look at message #3 and #5 from this post above?
So your commercial account is not showing any UI but your personal account login is ok with UI but crashes after a while, right?
Autodesk Fusion
Join Fusion Insider
Message 8 of 17
weihao_wei
Not working at the moment
It should not be because the app were running fine 2 weeks ago before the update, been using the app on the same PC for 2 years.
Message 9 of 17
weihao_wei
Yes
The commercial account is basically white screen after show "Connecting to data" after login
Personal account goes sudden crash 100% of the times after UI loaded (new update features pop up)
Message 10 of 17
RajkumarIlanchelian
@weihao_wei
Can I take not working at the moment means that you tried it and you are seeing the same result?
Also, can you disable windows defender and see if that helps? Windows often makes updates as well that can make changes.
Please also follow the link to he article to collect manual logs.
Autodesk Fusion
Join Fusion Insider
Message 11 of 17
weihao_wei
Oh crap! reset the firewall and now the personal account can be entered.
I can open file now.
Only thing I noticed
This area is blank
Message 12 of 17
weihao_wei
Alright firewall reset did something (Autodesk service are all allowed)
Trying the commercial account now, I know it is trial for now (if it works then yes I can request the purchase)
Commercial account stills shows blank screen, but the utility tool is working now
here are the automatic generated files.
Hopefully we can know what happened!
Message 13 of 17
RajkumarIlanchelian
@weihao_wei OK. We are heading in the right direction here. The logs shows that I am not seeing some of the folders I want to see. Let's do this.
1. Login to your personal account
2. Now properly logout
3. Close Fusion
4. Go to the service utility - Run the "reset Fusion"
5. Now go to C:\Users\(username)\Appdata\Local\Autodesk
6. Delete "Autodesk Fusion 360 Folder"
7. Go to %localappdata%\Autodesk\
8. Delete the "Identity Service" folder
9. Now start Fusion
10. It should ask you to login
11. Use your trial account
12. If the same problem happens NOW please collect logs and send again
Autodesk Fusion
Join Fusion Insider
Message 14 of 17
weihao_wei
Alright done the exact step by step
Still have the blank screen on trail account, the "gather system info" function now again, crashes/automatically closed.
However I followed the previous post and gathered all manual logs here, see attachment.
Thanks!
Message 15 of 17
RajkumarIlanchelian
@weihao_wei Can't find all the information I need in the logs as they are not even registering it. I am actively looking at it but will be a bit slow over the weekend.
When you Go into the Autodesk Fusion 360 folder are you seeing a unique value folder? This gets created asa result of your login per your account. Are you seeing this?
Autodesk Fusion
Join Fusion Insider
Message 16 of 17
weihao_wei
No worry by end of next week should be ok
This is what I see
Message 17 of 17
weihao_wei
Any updates?
