Announcements
Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Unable to delete appearance
FrodoLoggins
Advisor Advisor
FrodoLoggins
Only 1 material in this assembly. Only 1 appearance applied to the assembly. Yet I am unable to delete Plastic-Glossy (Black) as Fusion thinks it's assigned to something. It is not assigned to anything. Highlighting the material and selecting Unassign and Delete does not remove the appearance from the Appearances dialogue:
.f3d file attached.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
ryan.bales
Autodesk Support
Autodesk Support
It is applied to something - but not as an appearance. Their physical material is plastic glossy black. You'll need to modify the physical material in order to be able to remove it.
Ryan Bales
Fusion 360 Product Support
russellcrockett
Community Visitor
Community Visitor
Also unable to unassign and delete the physical material.
